9/20/2024 4:16 AM | |
Joined: 12/15/2019 Last visit: 9/12/2025 Posts: 11 Rating:
Hi Denilson is it safe to use View of things because site showing not secure? How can take protect data. ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 09/20/2024 07:41:54New subject after splitting |
9/24/2024 11:19 AM | |
Joined: 8/3/2009 Last visit: 9/12/2025 Posts: 16409 Rating:
Hello Tipre As already written, the webserver uses https and here a certificate is used for secure access. you have to install this certifiate on your system where the browser runs or also if you use a CA (depends on the browser) you have to addit to trusted cert stores.... there is no difference to any other secure webserver Check this FAQ: https://support.industry.siemens.com/cs/de/en/view/109803395 there are all steps explained regarding the certificate handling of VoT i the documentation Bye Murof |
