5/13/2025 8:51 AM | |
Joined: 8/3/2009 Last visit: 9/3/2025 Posts: 16322 Rating:
Hello matejak14 you should be able to import the Audit trail data from Comfort Panels into your WinCC V8 Audit: https://support.industry.siemens.com/cs/de/en/view/109977112/162304026251 If you use SIMATIC Logon with Comfort Panels you need also licenses. you need a "Logon Server", a PC with installed WinCC Logon Service. and here you need a logon Service license and also a SIMATIC logon Remote Access volume license (number of the Panels). On the Panels itself you do not need a license for this bye Murof |
