8/5/2025 6:25 PM | |
Joined: 4/29/2024 Last visit: 8/24/2025 Posts: 12 Rating:
dears greetings I am using windows 11 , 22H2 with wincc explorer v8.0 I configured auto start as the pdf attached procedures, and run it but unfortunately, I got server not found, other wise the project can run with out any error when open it by wincc explorer !!1 any help please to make it activated by autorun option thanks AttachmentIMG_20250805_173032.zip (17 Downloads) |
8/6/2025 8:23 AM | |
Joined: 8/3/2009 Last visit: 9/5/2025 Posts: 16349 Rating:
Hello ali be The WnCC Autostart is primary made for starting the WinCC project at startup. If you want to start a WinCC project by shortcut you could also use CCStartStop.exe (you can use this since V7.5SP2/V8). here are all available ways: https://support.industry.siemens.com/cs/ww/en/view/109986766/185963541259 Bye Murof |
