11/13/2024 10:35 AM | |
Joined: 8/3/2009 Last visit: 9/16/2025 Posts: 16436 Rating:
Hello AutoGen_3930438 What happens if you create a new project, does it work to set this Project in RT or is it the same behaviour? you can try this but I think its not the reason in this case (but you can try to connect to SQL and check if everything is OK): https://support.industry.siemens.com/cs/de/en/view/109818900 Also reseting the dcf File could help in some situations: https://support.industry.siemens.com/cs/de/en/view/109763043 Bye Murof |
