9/6/2024 12:54 PM | |
Joined: 8/3/2009 Last visit: 9/12/2025 Posts: 16409 Rating:
Hello mEngineer Here is a quick overview which programming languages the different WinCC Systems use: WinCC V7/8/WinCC Professional: VB Script, C Script WinCC Comfort/Advanced: VB Script WinCC Unified: Javascript If you want to work ith WinCC Unified there are often ways to get things work with a Script if its to complicted for a common dynamization. But you will not have to be a professional programmer for Javascript. Often the Scripts are pretty easy. A good point to start and to have a look if you need something is this FAQ: https://support.industry.siemens.com/cs/de/en/view/109758536 And of course the Object model in the WinCC Unified manual. Bye Murof |
