8/6/2025 8:14 AM | |
Joined: 8/3/2009 Last visit: 9/1/2025 Posts: 16284 Rating:
Hello Aivaras2 perhaps some configuration of the Server/Client systems are not set up correctly. Use this checklists: https://support.industry.siemens.com/cs/ww/en/view/22132850
Then you could also try to renew the dcf file and Serverpackage: https://support.industry.siemens.com/cs/de/en/view/109763043 Then check also in the client Startup list if you have activated all you need. Do you use Clients with an own project or Clients without an own project? Bye Murof |
8/6/2025 8:28 AM | |
Joined: 3/4/2019 Last visit: 8/21/2025 Posts: 40 Rating:
In client pc im accesing project through network. Client does not have its own project. |
