12/30/2024 8:32 AM | |
Joined: 8/3/2009 Last visit: 9/12/2025 Posts: 16409 Rating:
Hello Mako2 You could use OPC UA (OPC UA Server in WInCC requires Connectivity pack License) This Example is a little bit older but could also help: https://support.industry.siemens.com/cs/ww/en/view/109479664 (Some details could be different in newer WinCC Versions) If you have the same PLC then you can also change information with PLC tags Bye Murof |
