4/29/2008 1:08 PM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating:
Hi, i did not realy know what you mean -> can you make a screen shot from your "problem"? Did you use flexible 2005 SP1 and HF7, if not maybe you should use the HF7 for 2005 -> http://support.automation.siemens.com/WW/view/en/24758642 Notes: After then you must update the images from the panel (new version!) regards |
5/7/2008 5:34 PM | |
Hi, did you read the "Readme_WinCC_flexible_2005_SP1_HF7.doc " There are all points described, which are solved. I am not sure if with this HF your problem solved. Maybe you should contact the simatic hotline. regards, |
