7/24/2023 5:58 AM | |
Joined: 1/21/2013 Last visit: 9/6/2025 Posts: 4090 Rating:
Hi rearea, For indirect addressing using SCL, you can use the instructions
However, it is recommended to work with data blocks instead of bit memory. Using an array variable there also allows indirect addressing, but in a simpler way. See programming recommendations and Programming Guideline for S7-1200/S7-1500. Kind regards |
