(6)| 5/30/2014 9:10 AM | |
Joined: 3/21/2006 Last visit: 1/10/2026 Posts: 10247 Rating:
How do you configure a PC station as DP master for connecting to a DP slave for the SIMATIC NET OPC server with the SIMATIC NET PC software? 2nd time...
| 5/30/2014 9:31 AM | |
Posts: 51 Rating:
not possible... |
| 5/30/2014 10:10 AM | |
Posts: 11 Rating:
dear sir, Plz do need full
| 5/31/2014 6:00 AM | |
Posts: 11 Rating:
Sir, Plz provide me any solution. |
| 7/3/2014 6:08 PM | |
Posts: 176 Rating:
New question split intoReplacement 6ES7-277-0AA20-0XA0 with 6ES7-277-0AA22-0XA0. With best regards, Narrator1
| 5/13/2016 6:16 PM | |
Posts: 59 Rating:
Dear Umencho, Kindly provide valid links................ |
| 5/13/2016 7:41 PM | |
Hello KKDA; Here are the new links that connect to the FAQs yu are looking fopr: How do you configure a PC station as DP master for connecting to a DP slave for the SIMATIC NET OPC server with the SIMATIC NET PC software? https://support.industry.siemens.com/cs/ww/en/view/29645558 How do you configure a PC station as DP slave for connecting an S7 station (as DP master) for the SIMATIC NET OPC server with the SIMATIC NET PC software? https://support.industry.siemens.com/cs/ni/en/view/16650883 Hint: If ever you face the same problem (links unavailable), know that the ID number of the document does not generally change in Siemens database, only the access link. Try copying the shortcut to the original link (right-click, Copy shortcut...) in a Word document, find the ID= number inside that address string, copy the ID number and search for that ID number in the search box at the right of this page. You should be able to find the new link easily. Hope this helps, Daniel Chartier |
