(2)| 7/15/2024 7:11 AM | |
Joined: 6/30/2014 Last visit: 10/27/2025 Posts: 476 Rating:
Hello alMajidi, hello everybody, I would guess that the salesperson of Siemens "To retrieve the **Composite Host ID (CID)** for your COMOS 10.5 license, follow these steps: 1. **Locate the getcid.exe**: - The `getcid.exe` utility generates the Composite Host ID. You can find it in the installation folder of your **PLM License Server**. - Alternatively, download it from the [GTAC support website](https://download.industrysoftware.automation.siemens.com/ugs_licensing/CID/). Navigate to your specific platform and locate `getcid.exe`. 2. **Run getcid.exe**: - Double-click `getcid.exe` to run it. - It will display the hostname and Composite ID. Note that you should focus on the Composite Host ID associated with the **Ethernet (wired) network connection**, not the Wireless (Wi-Fi) connection. 3. **Register the CID**: - After generating your Composite Host ID, register it via the [License Management page](https://www2.industrysoftware.automation.siemens.com/LicenseManagement/Application) on the GTAC website. - You'll need a WebKey Account to access this page. If you don't have one, follow the instructions for creating a WebKey account. Remember, the CID uniquely identifies your machine for licensing purposes. If you encounter any issues, Siemens support can assist you further." Here below you see the link to get the documentation (so called DokuPack) for the various COMOS versions: Technical documentation COMOS: Documentation Portal - ID: 109776498 - Industry Support Siemens They have released a new DokuPack for COMOS 10.5, you can download it from there: at best you use the PDF file in it to search the whole package for any keywords you like/need. All the very best, SuperPippo |
