(0)| 11/30/2007 5:21 PM | |
Posts: 7 Rating:
Hi all, I have the same problem as published within this thread: Simatic Net Problem with S7-200 via CP 243-1. Everything worked fine until I installed a new version for STARTER. Now, I'm configuring the Ethernet module, is running, when I ping the address is responding but when I change the PC interface from PPI to Ethernet, S7 is seeing the address as unknown and I can't make it work. Where can I find the tools to diagnose??? Please advise! Thank you! C |
Last edited by: CS Moderator at: 01.12.2007 13:51new subject after spliting referred thread inserted Last edited by: Cristodul at: 30.11.2007 17:21 |
