10/4/2022 11:12 AM | |
Joined: 10/4/2017 Last visit: 4/24/2024 Posts: 10 Rating: (0) |
Hi Way, Have you found a hsp file for this? I am facing the same issue, we used before 6ES7137-6AA00-0BA0 but we got 6ES7137-6AA01-0BA0 but it is not in the hardware catalog and I could not find it. If you solved i would like to know Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/04/2022 11:40:29New subject after splitting emreas |
10/4/2022 11:49 AM | |
Joined: 1/21/2013 Last visit: 4/26/2024 Posts: 2714 Rating: (440) |
Hi Emre_Aslankara, same issue, same solution. Please read the release note which was linked in the previous thread by mopS04. There you will find the following: The modules are fully integrated in STEP 7 V17 (TIA Portal) and do not require any additional add-on packages. You won't find the module in hardware catalog for TIA Portal versions prior to V17. Kind regards |
