11/8/2022 12:52 PM | |
Joined: 8/3/2009 Last visit: 4/25/2024 Posts: 12869 Rating: (1640)
Hello Dileee on the CF Card there are no project data, only logged data or recipe or similar (user data). So often there is an active access rto the card while runtime is running. I Would recommend stopping the Runtime and then you can safely remove the CF Card. Then you can try to restore on the other panel. A restore usually should only take a few minutes. you have to activeate the restore manually: https://support.industry.siemens.com/cs/ww/en/view/28928853 Bye Murof |
Last edited by: Murof at: 11/08/2022 12:53:45If this Information really helps, you could use the Rate function |
