10/28/2016 2:15 PM | |
Joined: 7/9/2015 Last visit: 1/30/2023 Posts: 3277 Rating:
Hi, before updating I would check if the new Version is still compatible with other versions installed at you PC. Generally I would say that a newer Version works with better performance and new functions... Therfore you can use the compatibility tool: https://support.industry.siemens.com/kompatool/pages/main/index.jsf? Regards, Towome |
If my post was useful, please rate me - thank you! |
12/1/2016 7:30 AM | |
Posts: 1 Rating:
Hey I have such a problem as in the picture maybe someone something to help. |
12/1/2016 8:09 AM | |
Joined: 5/12/2006 Last visit: 1/30/2023 Posts: 21199 Rating:
Hello, you must Install SP1 and then UPD9 fpr Step7 Professional V13. You must install Startdrive V13 SP1. Regards Christoph |
2/1/2017 4:19 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4839 Rating:
New question published by fiah is split to a separate thread with the subject Installation of STEP 7 V13 SP1 on same PC with STEP 7 V5.5. Best regards |
