3/31/2010 10:27 AM | |
Joined: 12/9/2009 Last visit: 4/5/2022 Posts: 156 Rating:
Hello, please check compatibility STEP 7 and Windows Operation System: http://support.automation.siemens.com/WW/view/en/8250891 Here you can download SP5 for STEP7 V5.4: http://support.automation.siemens.com/WW/view/en/36184684 STEP 7 V5.4 SP5 is supported by Windows XP SP3 When you have a compatible system and the error message still comes then I advise you to contact the customer support by Support Request. They can analyse your system and can find out the reason. Best Regards |
12/25/2022 9:26 AM | |
Joined: 9/5/2020 Last visit: 3/29/2023 Posts: 45 Rating:
Hi, I have the same problem; could you please tell me the solution if you found it? Best regardes, Nayef Yahya |
