12/15/2022 11:03 AM | |
Joined: 9/23/2005 Last visit: 2/6/2023 Posts: 4090 Rating:
This may be of your interest. |
Regards, |
12/15/2022 11:41 AM | |
Joined: 9/27/2006 Last visit: 2/7/2023 Posts: 11951 Rating:
Hello; First look at this discussion on different Safety implementation on Fire and Gas systems: https://www.linkedin.com/pulse/which-type-fg-control-system-meets-your-requirements-hossein-nikuee So, basically, this is a Safety system that is based on a F-CPU (Safety CPU aka Failsafe CPU) a S7-1200FC CPU in your case using Functional Safety program blocks for S7-1200: The burner library pointed out by JacekD shows an example of how to use Safety blocks, you should study it carefully even ic uour project is slightly different. Hope this helps Attachments71200_f_user_manual_en-US_en-US.pdf (8 Downloads) |
Last edited by: dchartier at: 12/15/2022 11:44:34Last edited by: Jen_Moderator at: 12/15/2022 13:13:54PDF added from link. |
