4/18/2012 5:02 PM | |
Posts: 131 Rating:
i want to do a dinamic structure in lad languege on tia portal v11 and i dont know how need help
4/18/2012 5:29 PM | |
Posts: 131 Rating:
i want to create 10 inputs and if the person will like to change the size i will only need to change the number of the array |
4/19/2012 11:27 AM | |
Posts: 131 Rating:
i want to change the size of the array on runtime is it possible? |
4/19/2012 12:23 PM | |
Joined: 3/24/2009 Last visit: 7/9/2024 Posts: 535 Rating:
unfortunately not Best regards, yy1 |
4/19/2012 12:51 PM | |
Joined: 1/28/2009 Last visit: 1/30/2025 Posts: 6859 Rating:
Hello again, Try to see how we create a arrays.They are memory areas inside CPU and they should be allocated for this specified purpose(see here for a 2 dimension array). In case of over design it is waste of CPU's resources which may be vacant for some times.Best way to re construct a new feasible solution. Best regards, Hamid Hosseini |
