12/6/2009 3:47 AM | |
Joined: 10/7/2005 Last visit: 6/9/2023 Posts: 2969 Rating:
Dear blazer Navnaghas had good reasons to ask you (twice already) for the type of S5 CPU and (E)EPROM that you are using as thereare quite some differences in the handling. I wonder if you are perhaps not in a position to divulge this information and if so there isanother "trick" you can use: 1.)Go to https://support.automation.siemens.com 2.) Type your CPU part number into the "Self Help" field and click on "Go" 3.) Filter the search results by "Manuals" and donwnload the manual for your S5 CPU In it you will find information about(E)EPROM handling and the other manual worthwhile searching for, downloading and consulting in your case is the STEP 5 programming manual (which will also be on your Step 5 CD and/or already on your harddisk and has a chapter relevant to (E)EPROM burning). I hope this helps |
Cheers |
