4/3/2012 12:14 PM | |
Posts: 60 Rating:
Thanks Aret, So, i will start to make my own code - I put it on main cycle, so it will be executed every time. I have tried to put it on OB30, but my other function goes wrong (inconsistency scan time, i guest). I use indirect addressing and indirect typical for my Object, and with execute the Function in OB30, all my Indirect typical didn't execute properly. - Here i attached my FC in pdf, Regards Layudhi AttachmentFC1.pdf (145 Downloads) |
4/6/2012 8:46 AM | |
Posts: 2348 Rating:
I got only 1 suggestion besides writing your own code - try to separate NW10 into 2 pieces - 1st with READ_CLK, 2nd with LT_TO_BT. |
