7/22/2009 12:09 AM | |
Joined: 6/13/2006 Last visit: 2/11/2023 Posts: 341 Rating:
See the following FAQ. http://support.automation.siemens.com/WW/view/en/22387424 regards, rit03 |
7/22/2009 3:35 AM | |
What do you mean by editing ethernet node. Could you attache screen shot where you stuck. regards, rit03 |
7/22/2009 3:54 AM | |
You can use Primary Setup tool to configure IP Address through MAC address. See this link for Primary Setup Tool http://support.automation.siemens.com/WW/view/en/19440762 regards, rit03 |
7/22/2009 4:05 AM | |
Joined: 12/20/2008 Last visit: 8/12/2024 Posts: 556 Rating:
Already did this one, Installed, and tried to communicate to CPU, does not detect the CPU. Any other solution? |
7/22/2009 4:09 AM | |
Have you powered the CPU with +24 Volts on both the terminals provided on it and grounded. regards, rit03 |
