11/17/2020 11:17 AM | |
Joined: 4/23/2010 Last visit: 1/29/2023 Posts: 7962 Rating:
Hello, Depending upon motor power & application you need to select Sinamics drive. Next you need to check compatability of CU unit you have with drive module & then you run your motor with drive which operation can be controlled by CU. Please refer SINAMICS S120 Getting Started with the STARTER Commissioning Tool application example for more detail information. HTH |
11/27/2020 5:47 AM | |
Joined: 5/12/2006 Last visit: 2/8/2023 Posts: 21237 Rating:
have you connect the 230v correctly? the messages mean that only the 24V available but not 230V on the Powermodule |
12/3/2020 8:01 AM | |
Hello, Please refer below application example. SINAMICS G/S: Speed control of a G120/S120 with S7-300/400 (STEP 7 V5) via PROFINET (PROFINET RT) Positioning a drive with standard telegram 9 SIMATIC S7-1500T: Control of a Multi-Carrier-System HTH |
