2/23/2007 1:42 PM | |
Joined: 12/5/2005 Last visit: 8/20/2024 Posts: 239 Rating: (9) |
Hi, You can see more informations about compatibility of Simatic IT in this manual: Now, see the attached picture. Well, as I said previously, I'm notspecialist in Simatic IT, but in the this picture, andbased in theinformation in the manual of Simatic IT, the communication between RTDS and Process Values of WinCC is based on OPC DA, and Wincc is compatible with OPC DA 2.0. Now, the historical data of WinCC is sent to Simatic Historian by OPC HDA, and until I know, the WinCC 5x haven't the implementation of OPC HDA. Professional life goal: I stilldo a project with Simatic IT! |
Márcio Santos |
2/27/2007 10:22 AM | |
Joined: 8/10/2006 Last visit: 7/15/2024 Posts: 156 Rating: (3) |
I agree with you that it is possible to generate customize reports in Report Mgr. But the referesh rate of the reports is like 20 minutes for 12 Tag values. I am attaching the report, if anyone can find a problem in it. Thanks in advance Raheel AttachmentKN_PRESSURE1.zip (778 Downloads) |
