1/20/2015 9:51 PM | |
Posts: 3 Rating:
I am using the web page in a s71200, if I delete a Webint:PLCtag or create a new project when I compile it says it cant find the tag even though it is deleted. If I start a new project I get warnings from the last projects web data when I compile. Example WebInt PLCtag"webdata".I_Int not found. If I delete I_Int from the webdata DB it still gives a warning. If I create a new project this still comes up. ---------- New subject after splitting from S71200 PID Input. |
7/9/2015 11:06 PM | |
If you just generate new web page blocks and download again after you make those changes, it should work fine. The generate blocks is not part of the compile and must be done manually, then download to the plc.
science guy |
