5/2/2008 8:15 PM | |
Posts: 2661 Rating:
I think you have not defined the start picture. Run the OS project editor on the client. |
5/4/2008 11:35 PM | |
Posts: 2661 Rating:
valmet: The statement made earlier that the start picture is defined in the server is wrong! Every WinCC project whether client or server (or single station) has a start picture. I recommend that you create a test WinCC client project so that you understand what exactly is a start picture. The attached document describes the step-by-step procedure. Regards, Phantom AttachmentWhat is start picture in a WinCC Project.pdf (877 Downloads) |
