5/4/2007 9:53 PM | |
Posts: 324 Rating:
Hello Ilyaz, well, to tell you the truth, you will not see SCALANCE W inSTEP 7. For you, as a User, this is only a wire... even if you have no wire. The following Document shows you the most information: SCALANCE W788-1PRO (Access Point), SCALANCE W788-2PRO (Dual Access Point), SCALANCE W788-1RR (Access Point iPCF) SCALANCE W788-2RR (Dual Access Point iPCF) ANT792-8DR (Directional Antenna 2,4 GHz) ANT793-8DR (Directional Antenna 5 GHz) I hope this helps you a bit. Stay calm. |
