(2)| 1/2/2014 1:20 PM | |
Posts: 642 Rating:
Hello Eng. Mohamed, have you solved your problem here? /tf/WW/en/Posts/101854#top It is lack of understanding of the structure of the area pointer! Screen entry no and Current field no are not the same!! Screen entry no is the no of the subscreen. In Protool is a BYTE, in WinCCflex is a INT. You are sure when you move INT to BYTE? Regards André Räppel --------------------------------------------------------------------------------- www.raeppel.de work faster withinnovative PLC-Tools |
| 1/27/2014 12:02 PM | |
Posts: 340 Rating:
new question is splittet to I want to change the OP177B to some other HMI. |
