(0)| 9/29/2023 9:28 AM | |
Joined: 1/21/2013 Last visit: 1/13/2026 Posts: 4393 Rating:
Hi Constantin/siemens, Because you are writing, you cannot start the Automation License Manager, so you cannot transfer the licenses. Attempting to move the files to another machine using simple file transfer will corrupt your licenses. However, it should be possible to move the disk from the broken PC to another PC where the Automation License Manager is running. There you should be able to transfer the licenses. Or you can create a support request for "Licensing / Authorization" to contact the license management support to clarify how to handle the problem. Kind regards |
| 9/29/2023 12:21 PM | |
Joined: 7/5/2013 Last visit: 1/13/2026 Posts: 3274 Rating:
Hello Constantin,
if PC resp. Windows is not running, then, I guess, you can't transfer the licences. If you can start your PC somehow then make sure to have the latest version of ALM installed, because also for service request this would be required. Latest version can be loaded from Handling programs for authorizing or licensing SIMATIC products. ( ALM, TIA Administrator, Authors). Regards, Frink |
Pi is exactly three! |
| 4/21/2025 10:29 PM | |
Joined: 5/27/2024 Last visit: 9/2/2025 Posts: 1 Rating:
Good mornig i have problem, how to transfer my master license to replace trial license Thanks for your support. |
