3/10/2022 2:36 PM | |
Joined: 8/3/2017 Last visit: 12/10/2024 Posts: 27 Rating:
It was different, but changing it didn't do the trick... And if that was the problem, it should transfer by USB i think? |
3/10/2022 2:47 PM | |
Joined: 4/24/2006 Last visit: 7/31/2025 Posts: 9027 Rating:
Hi, Is your PC directly connected to Panel? What IP Address have your PC? (Can you ping panel?) Check this faq: Why can you not transfer the HMI configuration to the panel? How can you transfer a WinCC (TIA Portal) configuration to an operator panel using Ethernet? Best regards, Wizard |
2/4/2025 8:17 AM | |
Hello, If you have the original project, you can try to Reset the panel. Best regards, Wizard |
